Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Does your Corvette look like this?
Old Jun 6, 2006 | 03:09 PM
Richie Carbone's Avatar
BADA BING BADA BOOM!!!!!!
Originally Posted by Nine Ball
I'm going with a DTE rearend and 3.90 gears.
There goes traction in 1st and 2nd with the maggie!
Old Jun 6, 2006 | 03:17 PM
Nine Ball's Avatar
LS1Tech Co-Founder
never had traction before on stock tires Richie. The main problem is crossing thru the traps at only 5K rpm in 4th gear, when my shift point is 7K. Falls flat on its face in 4th at the track. Amazingly it went 129.5 mph at low rpm
Joe, PM me details on an upgraded mainshaft.
Old Jun 6, 2006 | 03:30 PM
SPANKY LS1's Avatar
Yours had 3.42s also, right? Interesting to see how much the 3.90s help (SOTP wise), going from 3.42 to 4.10 in my Camaro had about the same SOTP inprovement that heads and cam did. How many miles your car got on it? I wonder how much stronger the 2006 rearend is? Hmmm.....
Old Jun 6, 2006 | 03:31 PM
jbusmc1986's Avatar
awesome man... I am about to have to do much of the same, how much does it usually run to upgrade the mainshaft??
Old Jun 6, 2006 | 03:51 PM
ls1 joe's Avatar
Depends. Right now we are having them made for us for the Z06 and C6 transmissions but will only be offering a 300M unit as the 9310 was not recommended on the applications we do. We are looking at about 2 weeks upon completion and they will be a T56Rebuilds.com custom unit. They will be good up to 1300rwhp but of course the stock gears will not. They will be retailed at $1200 plus labor is a standard $350. We will also be offering a upgraded gear set to handle 1300rwhp but that is still in the works. They will also have warrantys on them.
Thanks,
Amber
T56Rebuilds.com
Old Jun 6, 2006 | 04:08 PM
Nine Ball's Avatar
LS1Tech Co-Founder
Spanky, my car has 7K miles on it, 1K with the blower/cam. All 6-spds have 3.42s. With my current combo, 4.10s would be the best for the drag strip, but thats if I never add any power. Hard to fit a 28" tire on a 15" wheel under a Corvette, haha. The 3.90s give me room to grow, and hopefully put me closer to redline going thru the traps. I have a methanol kit to add to the car before the next visit. A few other Corvette racers suggested I used ET Streets instead of ET Radials, to help absorb the shock loading on the rearend. I'll take their word for it, this one busted WAY too easily. 1.8 60' times and no wheelhop, no clutch dumps, and cracked the case all the way thru.
'06 cases aren't much better, they just relocated the mounting ears further out to spread the load better. Mine failed at the rear, so the mounting points had nothing to do with it. The rear of the '06 case is the same as the '05 unfortunately.
cracked differential case pics:
www.ls1tech.com/05Vette/diff09.jpg
www.ls1tech.com/05Vette/diff10.jpg
www.ls1tech.com/05Vette/diff11.jpg
Old Jun 6, 2006 | 04:25 PM
SPANKY LS1's Avatar
Think their brace would help any?
Old Jun 6, 2006 | 04:28 PM
Nine Ball's Avatar
LS1Tech Co-Founder
It should, I ordered one.
Old Jun 6, 2006 | 06:27 PM
Hardtop's Avatar
Looking good Tony, just remember to say no to DR's. The ET Streets are the way to go, and you'll probably be doing 1.6-1.5 60's in no time. That ET of yours should drop a bunch with them. Good luck.
Bruce
Old Jun 6, 2006 | 07:00 PM
pdd's Avatar
pdd
been there-done that twice-good luck with it
Old Jun 6, 2006 | 07:22 PM
vince3's Avatar
yes, my z06 has the rear and tranny out right now.
Vince
Old Jun 6, 2006 | 08:41 PM
  #32
jargan04's Avatar
Hopeing mine will not be like that soon.
Old Jun 6, 2006 | 09:00 PM
  #33
Toxic Texan's Avatar
Wow Tony!!! Are you going to make a broke list? Like when you had the formula.
Old Jun 6, 2006 | 09:15 PM
  #34
Steve01SS's Avatar
Yup... a couple times. This was during a broken torque tube replacement.
Attached Thumbnails Does your Corvette look like this?-intheair.jpg   Does your Corvette look like this?-transandtube.jpg   Does your Corvette look like this?-brokentorquetube.jpg
Old Jun 7, 2006 | 06:13 AM
  #35
PA Z06's Avatar
Wow tony, good luck.
No power tour this year
Old Jun 7, 2006 | 08:20 AM
  #36
WizeAss's Avatar
Good point. Might just do that....
WONDER WHY YA COULDNT GET IT FIXED UNDER WARRANTY??? LOL
Old Jun 7, 2006 | 11:58 AM
  #37
lt197formula's Avatar
will be damn nice when its done though
Old Jun 7, 2006 | 09:02 PM
  #38
jic's Avatar
jic
good shiet
Old Jun 8, 2006 | 04:42 PM
  #39
NYC Vette's Avatar
I would give soooooo much to have a driveway or a garage where I could work on my car. Kiving in New York Apts. can really suck when you love cars.
Old Jun 8, 2006 | 10:06 PM
  #40
T/A-Speedfreak's Avatar
Wink
Tony, it looks expensive. You should sell me your 69', that will help pay for everything.
