Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
C5 Engine swap
Old Jun 6, 2006 | 11:06 AM
Bad Habit Bird's Avatar
Default C5 Engine swap
How hard is swapping the engine in a C5 compared to doing it with an F-Body? Also how hard is it to swap out the clutch? I can't seem to find any links on how to do either
I was also wondering if the C5 and F-body clutches are interchangable, can my ram 910 VDS system work in a C5?
Old Jun 6, 2006 | 08:48 PM
Steve01SS's Avatar
Lil more involved, since the drivetrain is more complex with the torque tube and all. Also, the C5 steering rack is kinda a pain to deal with....
The Clutches are the same. Yes they are interchangable. The only things that aren't, are the master and slave cylinders.
Old Jun 6, 2006 | 10:02 PM
SteveDoten@ARH's Avatar
Closed ex-Sponsor Account
ck out my avatar, you can have the motor out and the new one on the cradle in about 6/7 hours, this is after you've done a few and using a 2 post lift; also dropping out he bottom as a complete assembly allows the a/c and brake lines to remain unopened
Old Jun 7, 2006 | 07:45 AM
Hodge's Avatar
Check out the pics of my swap. Drill through the links in the web site listed in my signature.
Old Jun 7, 2006 | 08:15 AM
Thanks for the input guys! Hodge, your website with pictures helped a TON. I bookmarked it for when the time comes to do the swap
Old Jun 7, 2006 | 10:08 AM
Hodge's Avatar
Glad to help. One day when I have spare time I'll create a specific how-to document. E-mail me if you have specific questions.
Old Jun 7, 2006 | 11:06 AM
algws6's Avatar
Sean, did you buy a vette?
Old Jun 7, 2006 | 11:37 AM
Thanks again, I will look forward to your write up.
Working on it I am just looking for the right car right now (02-04 Z06). I would order an 07' but 08' ~ 10' are going to be pretty big years for the vette's and I don't want to wait that long to get one, so a C5 Z06 will give me the most bang for my buck right now. I will just demod the camaro, swap the motors and sell the Camaro with the LS6 motor.
I saw in another post you have the rear out from under your car, whats up with it?
Old Jun 7, 2006 | 03:26 PM
algws6's Avatar
it started knocking bad so i am putting in a DTE unit.
Old Jun 7, 2006 | 06:28 PM
96-speed's Avatar
Do you have to pull the engine (like Hodge) for a heads/cam swap on a C5?
Ryan
Old Jun 7, 2006 | 06:45 PM
linn.35's Avatar
http://www.cajundude.com/engineswap.htm
