Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Need opinions....Engine/twinturbo ?s
Old Jul 29, 2006 | 12:21 AM
madradvette00's Avatar
Default Need opinions....Engine/twinturbo ?s
Ok so here it goes. I have just ordered an SLP short block 402. I got heads and intake manifold on the way. 239/24? cam(dont remember exactly)....I got a FAST 90mm intake manifold and TB on the way. STS remote twin turbo set up with upgraded turbos and some extra stuff....
Should I run a 100 shot of direct port N20??? I have talked to a few people and they say yes and some say no. what do yall think?
Old Jul 29, 2006 | 12:34 AM
jbusmc1986's Avatar
Absofreakinglutely.... sounds great, You will love the nitrous.... although, I have heard that those shortblocks (SLP 402's) were not actually built with forged pistons, they also dont include the needed ls1 or ls6 to ls2 parts like scdpc does.... i would double check on that or cancel that order and order from scdpc or tsp or one of the other reputable engine builders, That is what I have been told from other sho went that road and their motors blew up, one in the first two weeks.... just be careful
Old Jul 29, 2006 | 12:58 AM
nc z28's Avatar
being an slp 402 id run an alky kit and not nitrous
Old Jul 29, 2006 | 02:15 PM
jbusmc1986's Avatar
Yeah.... I was kinda just trying to steer him away from that short block at all. That is a good point though.... it may not handle that if you keep the slp 402, So like I said be very carefull
Old Jul 30, 2006 | 12:24 AM
Yea I have talked to a few people and they say the ALKY kit is the best way to go... I am also going with a dif. cam. with more exhaust than intake...
Old Jul 30, 2006 | 12:48 AM
nc z28's Avatar
check out ecs for the alky system. while your check out their fuel and paxton systems as well. top notch!! the last forged 347 they did made 730+ rwhp w/ 13 ibs of boost and stock heads.
Old Jul 31, 2006 | 12:43 PM
MGorman's Avatar
I’d skip the nitrous and go with the alky injection.
That cam sounds way too big to use with twin turbos. With a forged 402 and properly sized STS turbos you should be able to make close to 800rwhp with a cam in the low 220’s duration if everything is dialed in correctly.
If the SLP short block isn’t forged you are going to have major issues……
