I think I just bought the corvette from hell....
DTC P1571 Traction Control Torque Request Circuit
DTC B2283 Battery #1 Circuit
DTC B0521 Tachometer Circuit Malfunction
DTC U1176 Loss of Communications with RFA
DTC U1160 Loss of Communications with LDCM
DTC B2242 Memory 1 Switch Circuit
DTC B2285 Battery #2 Circuit
DTC B2263 Horizontal Position Sensor Circuit
DTC B2262 Horizontal Position Sensor Circuit
DTC B2265 Vertical Position Sensor Circuit
DTC B2264 Vertical Position Sensor Circuit
DTC U1064 Lost Communications with BCM (twice)
Holy **** that is a lot of codes. I'd like to believe that one of those would have set the "check engine" light, but it never turned on. I just bought the car, I wonder if they guy who sold it to me pulled the bulb out of the check engine lamp.
Are all of those related? Could they all be stemming from a poor quality alternator or something?I don't even know what half of them are.
also my car goes into low power mode seems like every time i drive it, sux
-=Rick
I'm gonna erase all the codes, and check the fuse for my tire press. sensor and key FOB radio reciever. Neither of those systems is working right now.
I agree!
Those codes may have been there for a while.
Dont sweat it, just clear them and move on!
THe following returned after a short drive
RTD No Comm.
10-PCM P0410 C.............Secondary Air Injection (AIR) System
P1571 H............Traction Control Torque Request Circuit
80-Radio U1016 H............Loss of Communications with PCM
BO-RFA U1096 H..............Loss of Communications with IPC
U1064 H..............Lost Communications with BCM
THese sound to me like a couple blown fuses, or a nightmarish short somewhere. They aren't affecting drivability at all, but I don't want any kind of deep routed problem to grow.
im using a z06 85mm MAF
codes are
p1515 h - control module throttle acuator postion performance
p1516 h- throttle acuator control
p1626 h- theft deterrent fuel enable signal
p1638 h c - generator
c1278 h- tcs-temporarily inhibited
c 594 h c- right rear solinoid open
u 1096 h
u 1064 h
u 1016 h
u 1160 h
c 2120 h c tire pressure
i keep clearing the history codes but they come back
the p1638 h c is the generator- i installed a 200 amp alt three years ago and always got this code ever since with no issues
c2120- i have no tire pressure gauges-never an issue in years
c594 right rear solinoid open- im goona check this out, but the manuel says it shouldnt go into low power mode cause of this
the u codes are from dissconnecting the battery. i dont get it.
I'm concerned about the gauges though. I used a voltmeter to measure the battery and alt. while the car was running. both had 14.5 volts. The inside gauge never showes more than 13.1 though. Whats up with that? The oil press gauge also shows between 32-40psi all the time. I thought the OP was supposed to be higher.
When I start the car, the gauges are really slow to rise to thier correct readings. THe volts and oil press both rise to 13V and 38psi over about 5 seconds. Do all vettes do this?
its almost funny now!
