Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Vram installed
Old Oct 14, 2006 | 10:12 PM
Linxs's Avatar
Default Vram installed
well the vette is no longer a virgin. I instaled a vram today. Not really a very hard install.
I took teh car for a spin and notice throttle responce was much better and it deffinately felt stronger.
I'm looking into headers then I'll get it tuned.
Old Oct 15, 2006 | 07:50 AM
BOTTLE ROCKET's Avatar
Good mod; Jus wait till the weather gets a little cooler and you'll really notice a difference!
Old Oct 15, 2006 | 10:00 AM
michael402z06's Avatar
i am getting ready to buy one within the next couple days. how long did it take you to install?
Old Oct 15, 2006 | 11:49 AM
Linxs's Avatar
about 2 hours. I did not follow the instructions that came with it.
1. remove the old intake.
2. remove the baffle (the directs air flow to the radiator) remove the (7) 7mm bolts.
This will give you access to the fog light areas.
3. un bolt the 3 bolts holding the black plastic peice. You do not have to remove the fog lights to get the 3rd bolt you can push the brake cooling tube out of the way. (you'll see once you get started on it). Or you can do it like instructed by removing the access panel (still hard to get at though).
4. With everything out you can start putting the new system in.
Again, it's not hard, but I am accusomed to installing stuff. My camaro is extensively modded and I have done all the work.
Old Oct 15, 2006 | 11:52 AM
sound pretty easy, plus i already have the old intake and stuff out of the car.
Old Oct 15, 2006 | 12:57 PM
white99frc's Avatar
although the vararam materially is a POS and is a PITA to install (took me about 2 hours as well, but there are so many tedious steps for just installing an CAI), the damn thing works well!!
Old Oct 15, 2006 | 08:41 PM
Linxs's Avatar
I have to admite I was not impressed with the material used. But, it does work very well.
Old Oct 16, 2006 | 09:07 AM
allngn_c5's Avatar
I totally agree !! I love the way the VaraRam system makes your car feel in cooler air temps. Just wait until you try to top out your car with the V-Ram system. Once starving for air, now you'll have plenty of air. My car pulls harder from 100- ??? then it does from 0-100. The ram effect is the real deal, but not really noticable until you are above 100 mph. Enjoy !! One last thing, get the K & N filter upgrade, VRams filters unless you have the new one are horrible. I have heard they replaced the old ones with a new "K & N" type. Either way, wash your filter regularly. Every 1000 miles or so, or at least check it. Everything gets rammed into the air box, newspapers, plastic bags, etc, etc.
Old Oct 16, 2006 | 11:08 AM
C5 Bandit's Avatar
yea definately grab the K & N filter for it. the original filter on mine broke apart and clogged up my MAF pretty quick.
Old Oct 16, 2006 | 11:10 AM
C5 Bandit's Avatar
youll also see big gains from headers and tune, they picked up 40rwhp on tuning mine after i had only the Vram and mufflers on.
Old Oct 16, 2006 | 12:31 PM
96-speed's Avatar
I'd be curious to see some before/after track times with notes of the weather/DA.
Ryan
Old Oct 16, 2006 | 01:08 PM
Linxs's Avatar
you picked up 40RWHP with just the Vram and a cat back system? Stock headers?
My filter looks almost like a K&N filter. I should still change this out?
Old Oct 16, 2006 | 02:20 PM
C5 Bandit's Avatar
yea the filter that comes with it flows very well but is very brittle. if it hasnt broken yet, it probably will lol. and yes sir i put down only 260 with the Vram and catback, the A/F ratio was off as well as the timing. it was dynoed here in FL on a muggy summer morning which could have had an effect, but after tuning i was just over 300
