Trans popping out of gear? HELP!!
If, on the other hand, it's popping out of 2d and say 3d, the issue is likely to be internal to the tranny.
Can't offer more than that, given the symptoms, as written.
Ranger
http://rpmtransmissions.com/files/c5...adjustment.pdf
If this adjustment doesn't bring relief, it's back to the dealer.
Most tranny issues derive from degenerated clutch fluid causing the clutch pedal to disengage incompletely on shifts. But I'd like to think that you've been keeping your clutch fluid clean since I showed you the procedure back at Carlisle.
Ranger
because it was just too impractical for what we needed. Ended up buying an Infiniti FX35 for her and I just picked up a brand new GTO 6spd a few weeks ago. I'm actually headed up to Cecil County this Saturday (provided the weather holds out) to get some baseline runs before I do anything mod wise. Hoping for some low 13s maybe high 12s. I just hit 1,000 miles so it should loosen up after a few on the clock.
P.S. After you showed me that, it was ALWAYS crystal clear!!
Keep that GTO clutch fluid clean too. That way the pedal will stay normal.
Ranger
Ranger
~Brian
