Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Vaccum ?????
Old Dec 27, 2006 | 09:54 PM
charlie c5's Avatar
Default Vaccum ?????
I have a 408 with a crazy cam . When you pull off the oil fill cap, will there be a vaccum? If so what causes the vaccum??? I pull off my cap, and get a huge vaccum.. Thanks guys...
Old Dec 27, 2006 | 10:51 PM
EXTANKER's Avatar
if your PCV is working ,yes you will have vac. if no pcv ya got an intake leak or something
Old Dec 28, 2006 | 08:51 PM
charlie c5's Avatar
I just ordered a new a new PCV. I think mine may be bad and for anly $4.00 it's a cheap guess.. But, I pulled the vaccum lines off the intake and the throttle body, then pulled the oil filler cap off the valve cover, and there is a huge vaccum into the oil filler neck.. Do you guys kow what causes tha?????
Old Dec 30, 2006 | 03:35 PM
charlie c5's Avatar
I pulled off the driver's side valve cover. Yes, well, I found our little problem... #7 cylinder rocker pedistol is broken. I can't believe it. I'll call Texas Speed on Wednesday. I'm sure Jason, and Jon will take care of me.. I'll let you guys know how it goes. The motor, heads rear-end and tranny only have 5 miles on it.
