Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
11's possible with N20 stock C5?
Old Jan 30, 2007 | 01:11 PM
wax's Avatar
wax
Default 11's possible with N20 stock C5?
Just curious if anyone has run their mostly stock C5 at the track with N20? I currently have just a cold air and cat back. I just installed a 100 dry on the vette over the weekend ,also installed some colder plugs. That should be plenty for the 11's I would think. The car is a 2000 A4. Anyone have anything close to that?
Old Jan 30, 2007 | 03:00 PM
Z O SICK's Avatar
I think it's possible depending on track prep and 60ft.
Tony
Old Jan 30, 2007 | 03:16 PM
wyndzer's Avatar
I went 11.7's with a 150 Nx kit
Old Jan 30, 2007 | 03:25 PM
n2oJOE's Avatar
i went 12.1 @117 on dr's with only intake and exhaust and 100 shot wet im sure its way possible
Old Jan 30, 2007 | 03:48 PM
Undecided's Avatar
No problem, an f-body with 100 dry shot will run in the 11's & they weigh 3600 lbs. I went 11.60's @ 117 with mine. BTW air lid, cat back, 100 dry,& DR that was it.
Old Jan 31, 2007 | 06:58 AM
wax's Avatar
wax
alright thanks for the info.
Old Feb 4, 2007 | 01:00 PM
hepcat's Avatar
i went 11.67 @ 118 with drag radials, vararam and a 125 shot (zex)
all else stock 97 c5
2 years ago
Old Feb 5, 2007 | 12:58 PM
marlowchris's Avatar
The key here is drag radials. Without the sticky tires you will be spinning half way down the track. Get some tires and you should be good to go.
Old Feb 6, 2007 | 01:27 PM
vetred's Avatar
yes AND A WHOLE LOT more IS possible,.......like, BLOWN head gaskets bent rods sucked valves,Broken rods AND much more BESIDES, DO your homework and read everything you can, there is a lot of experiance arround here and almost ALL of It (over 35 yers. old) will advise you to DO the SUPPORTING mods.!!!
Old Feb 10, 2007 | 06:27 PM
Pray's Avatar
There are two vetts that I know personally around here that both went 10.90's basicly stock with a 150 shot. Stock stall.
Old Feb 10, 2007 | 08:01 PM
wax's Avatar
wax
Some good times there. You guys shift the a4 or let it shift itself when going down the track. I have always sprayed a manuel and so far not a big fan on spraying the a4.
Old Feb 10, 2007 | 11:03 PM
Dragman's Avatar
been 11.96 in modded C5 with stock motor so that should put u in 11s.
Old Feb 11, 2007 | 01:00 AM
Robert56's Avatar
Stock C5, does that include the stock Z06?
Robert
Old Feb 11, 2007 | 07:00 AM
wax's Avatar
wax
Robert, what can I do to get a better nozzle placement? I have the bottle in a bag kit by compucar. If I put the nozzle probe thing in the middle of the 2 filters it just bogs down, like the maf is getting a direct shot and it is not liking it. I put the probe in one of the filters at the end of it. It is too much travel for the nitrous before it gets to the maf. DO you sell a nozzle that can work or that ring you have?
Old Feb 11, 2007 | 10:25 AM
Robert56's Avatar
Not sure what filter/cai system you have. A pic would be great. Also, what nozzle are you using ie: straight shooter or 90* or 70*.
Robert
Old Feb 11, 2007 | 07:30 PM
wax's Avatar
wax
I have a volant cold air kit, I dont have a nozzle, it is just a probe. It comes with the bottle in a bag kit. Which is just a plastic line into some cheesy probe. I think that is a major problem with getting the full hit on this kit.
Old Feb 11, 2007 | 10:43 PM
Robert56's Avatar
That'a a dual cone set-up? Yea, you need a proper nozzle to dispense the nitrous correctly. Even so, the probe or even an open ended braided line can work, but harder to make correct concerning a/f.
Robert
