Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Vortech's C6 Supercharger
Old Apr 26, 2007 | 10:29 AM
tbyrne's Avatar
Default Vortech's C6 Supercharger
Just received this from Vortech -
Vortech C6 Supercharger
Increases horsepower to 550 and torque to 472 lb/ft.!
Allows retention of all vehicle accessories.
Installation time is 14-20 hours.
CARB E.O. D-213-25 has been assigned to these kits.
2005-2006 LS2 Flywheel horsepower/torque:
stock-- (HP/TQ) 400/400
supercharged-- (HP/TQ) 550/472*
*estimated based on % increase @ wheels w/ 7.5 psi at 6500 rpm
4GS218-010SQ (satin)
4GS218-018SQ (polished)
Included components:
CCW rotation T-trim supercharger uses 6-rib
Air/Air charge air cooler increases performance and reliability of supercharger system.
Hand-held programmer controls ignition timing and fuel enrichment.
Fuel system upgrade includes larger fuel injectors.
Supercharger drive system includes all necessary belts and pulleys.
Cast aluminum mounting bracket mounts supercharger and spring tensioner.
High flow air filter and ducting reduce pressure drop.
Molded inlet duct optimizes available area to supply supercharger air.
Oil drain and oil feed assemblies allow for maintenance free operation.
Release Notes:
Tuning for other model years and transmissions is not yet complete. Specific models/years will be released as they are completed.
Custom ECM module reprogramming may be required when additional aftermarket parts are added such as a MAF meter, air filter, smaller supercharger drive pulley, large diameter headers/exhaust, etc.
You can give us a call at e-mail tbyrne@tbyrne.com for introductory pricing!
Tom
