Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
help with TCS codes p1571,c1277
Old May 24, 2007 | 07:01 AM
klymaxr's Avatar
Default help with TCS codes p1571,c1277
p1571,c1277 codes wont clear!!
Just installed a new stroker 428ci and after doing a wash of the engine compartment (coincidence??) I had these codes and the traction control light on the dash was lit up and at first the engine ran in a sort of limp mod but has since gone away but the codes still pop up. I dried every connecter to the ABS unit as well as the connecters along the frame heading to the wheels. now after that the abs light would appear intermitently ( it would clear and then not come back on for a couple of days) The steering rack was taken out several time to fix a small oil leak as well and I also installed the new C-6 Z06 brake package. Can anyone tell me, other than that the ABS might be pooched (worked perfectly for 30,000klm), what could be the cause...thanks in advance.
