Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Please help me out!
Old Jul 25, 2007 | 06:50 PM
alpha-boy's Avatar
Default Please help me out!
I have the MagnaCharger along with cam and headers, the problem is I'm getting this code
"Throttle/Pedal Position Sensor/Switch A Circuit Range/Performance"
what do I have to do to fix this? do I have to change Maggie's throttle or what? please help
can anyone explain this code for me? I know it's the throttle but what is the problem? sensor?
I also saw "UNKNOWN" code.
Thanks in advance!
Old Jul 26, 2007 | 12:26 PM
DocT's Avatar
TTT for ya. Id pitch in, but I have no idea what's going on...Good luck!
RT
Old Jul 26, 2007 | 06:02 PM
V-seriesTech's Avatar
Thanks in advance!
Ok, it's circuit... does the car run? Idle? Drive? Gonna just throw out some guesses....since I don't ave all the info.
The actual code would help alot.
Ahh,..check and see if it's plugged in. After that, remove the intake pipeing, to expose the TB,...have a friend KEY UP the car, doesn't need to turn it on, just key it up,..and YOU watch the TB. Have him or her press the throttle, and monitor motion.
What happens?
Ahh..doubtful but, check fuses. Check grounds if this is a recent installation.
Ahh...yeah, see if you can get the actual code man.
Old Jul 26, 2007 | 06:15 PM
~JOSHUA's Avatar
It said throttle "pedal" position sensor right?
Well, if so I'd look at the sensors that deal with the foot pedals...
Old Jul 26, 2007 | 06:30 PM
lol. werd.
Couple of 10mm should get the pedal off if needed.
Check that, if plugged in, check TB. OR just post the code.
