parking brake cable removal
Can any one tell me how to remove the parking brake cable from the parking brake assembly. I cannot get enough slack in the cable to remove it. Has anyone experienced this. I did not want to post a non- performance post here but I am running out of options. Thanks in advance.
The emergency brake cable runs through the tunnel and is attached to the rear tub.
What are you trying to change ? At a minimum you would have to pull exhaust and tunnel plate to access to cable to change.
You could get some slack by removing both rear tires and taking off the emergency brake cable ends (two 15mm bolts) each side.
Why are you changing ?
You need to disconnect the parking brake cable from the rear brakes? If so you have to bend all the tabs inward (they are all around it), use alot of patients and work it out.
1.) Reomove the center console and passenger seat.
2.) Disconnect the parking brake electrical connector
3.) Disable the park brake adjusters - ( Take of the two rear wheels), You'll see the parking cables attached to the levers, remove them. Best bet is to lossen the 15mm bolts that hold bracket in place.
4.) Remove the the parking brake mounting bolts.
5.) Disconnect the cable from the brake handle assembly.
