Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
ms4 in a 02 c5 Z06?
Old Oct 16, 2007 | 02:40 PM
scramblerman's Avatar
Default ms4 in a 02 c5 Z06?
was wondering what some numbers, hp and 1/4 mile, I would see from my car. I was told 450-480rwhp nothing on the 1/4 mile time. In the body shop and can't wait to get it back. Just curious as to if anybody knows or has a vette with similar mods to it. Thanks
kook's long tubes 1&7/8" race
noncatted 3" x pipe
stock ti catback
MS4
ported fast 90 intake
Ls2 tb
vararam
Old Oct 16, 2007 | 03:07 PM
pittman's Avatar
Default 1/4
we have very similar setups. I have a 224 cam with 109 LSA, AFR 225's, unported Fast, LG Longs, no cats thru stock TI's., V-ram & stock 342 gear.
Ran 11.33 in 52 degree weather straight from dyno tune. After my son (Sportside) re-tuned with Hp Tuners, I ran 11.41 in 90 degree weather. My best 60' has been 1.64 with 18 lbs in ET Streets. Couldn't go any lower because of swerving around on the big end. Also, that was granny shifting on a bad clutch. This season I have a new tranny and 390 gear from RPM, new clutch from RPS and a pair of skinnies to cure the swerving. Should see some times near 10.8 in cold air with some power shifting and 12lbs in rear tires. That is roughly 430 RWHP and 400 TQ. Here is a vid of the 11.33 & summertime 11.41 with a 5000 rpm launch's. Also is clip of cam. This should give you a rough idea where you are. Good luck, be safe !
http://s160.photobucket.com/albums/t...nt=Bob11-1.flv
http://s160.photobucket.com/albums/t...sDavid11-2.flv
http://s160.photobucket.com/albums/t...ZO6Exhaust.flv
Old Oct 17, 2007 | 07:54 AM
50_Dave's Avatar
My buddy with his 01 z06 has an ms4 cam, fast 90/90, asp pulley, lg longtubes without cats.
He put down 438 and 405torque
Old Oct 17, 2007 | 08:24 AM
robz*'s Avatar
noncatted 3" x pipe
stock ti catback
MS4
Ls2 tb
vararam
More realistically your rwhp will be in the 425-450 range.
That's good enough for 10's if you figure out how to drive it.
Old Oct 17, 2007 | 10:58 AM
thanks guys for your info.
seems like you guys really like the afr heads. may look into heads at the end of this year. won't have the car back for a bit yet, then get it tuned in spring time.
Yea robz, 10's would be nice! got 11's already.
