Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
z06 rear panels?
Old Oct 18, 2007 | 03:55 PM
SVT BAIT's Avatar
Default z06 rear panels?
How Much Do U Guys Think It Is To Get The The Rear Z06 Panels Everything Pins Etc?
Old Oct 18, 2007 | 05:11 PM
onebadcad's Avatar
Parts should run about $1,000.00.
Panels are not painted, so figure another $200.00-$300.00.
Installation, if you want such, should be another $200.00-$300.00.
Great investment, makes the C6 look meaner, not leaner.
Mine were done by V-Series/Jamie, saved me a bunch, thanks again bro'!!!
Old Oct 18, 2007 | 05:33 PM
SVT BAIT's Avatar
so its the panels does that include all the hardware like pins etc?
Old Oct 18, 2007 | 06:07 PM
onebadcad's Avatar
Each vendor that has posted has offered all of the parts (panels, bolts, pins, etc...) needed for $1,000.00.
Here are the parts:
ALL PARTS FOR REAR CONVERSION
Rear quarter panels
Left 15932449
Right 15932447
Rear Fender liners
Left 15874588
Right 15874589
Rear Brake scoops inner
Left 15842370
Right 15842371
Rear brake scoops outer
Left 15787683
Right 15787684
Rear inner brake ducts
Left 15842373
Right 15842372
Gurney Flaps (Mud Guards)
Left 15818636
Right 15818637
Seals
15881432 Need 2
Pushpin fasteners
11519444
One day you may do the front conversion, which includes the bumper:
ALL PARTS FOR FRONT CONVERSION
front Carbon Fiber Fender panels
Left 15779342
Right 15779343
Front Inner Fender liners
Left 15827791
Right 15827792
Front Outer Fender liners
Left 15834373
Right 15834374
Front Nose Clip
15915335
Chin Spoiler Lower
15834249
Front Grille Outer
15857168
Front Grill Inner
15822871
Various Items Nuts and clips
11517700 Need 3
10330821 Need 1
10330822 Need 1
11609411 Need 8
10342936 Need 1
10342937 Need 1
11609489 Need 6
11589259 Need 6
11609489 Need 12
11515638 Need 12
11609487 Need 5
11609871 Need 2
Seals
15881433 Front Nose Seal
15774161 Need 2 1 for each fender
Also if you need a new c6 emblem for the new nose
10370896
Also note on front
You will reuse brake duct tubes and most clips
Here is the link from which I pulled the info:
http://forums.corvetteforum.com/show...light=widebody
Old Oct 18, 2007 | 06:17 PM
SVT BAIT's Avatar
so theres actually a few companys making them?
Old Oct 18, 2007 | 06:31 PM
onebadcad's Avatar
More than a few, search this Forum and others, some do group buys over at the 'other Forum'. Biggest savings is have a friend at any GM dealership get them for you and paint match to your gas door; red should be an easy paint match.
Of course you will now need rims (plan to do the fronts oneday, so make sure you buy front rims, preferably 9.5" with correct offset for stock panel, as you can run a 265/275 size) and 345rears, so budget for that.
For tires look into the PS2s or Nitto Invos, Discount Tire is running a special right now with $100.00 off when you buy 4, with free shipping.
Old Oct 18, 2007 | 06:53 PM
SVT BAIT's Avatar
so if i get the z06 panels what size rim and tire would i need to run?
sorry for all the questions but i wanna do it right the first tyme
Old Oct 18, 2007 | 07:30 PM
BLK02TA's Avatar
12" wide rim
Old Oct 19, 2007 | 12:28 PM
onebadcad's Avatar
BLK02TA 12" wide rim-Dead on!!!
If you buy new rear rims, you will need front, so go with the following:
F=18 X 9.5, run a 265, as I do not know if 275 will rub w/o front conversion
R=19 X 12, run a 325/335/345, all will work
Here is a tire calculator to help you:
http://www.1010tires.com/TireSizeCalculator.asp
I have a 265/35/18 up front and a 345/30/19 in the rear
You can four C6Z rims from most Corvette parts vendors for under $1,000.00 in chrome-I powdercoated mine black for $50.00/wheel.
Here is my math for the rear conversion with rims and tires:
Panels=$1,000.00
Paint and install=$500.00
Rims=$1,000.00 (add $200.00 for powdercoating or painting)
Tires=$1,000 for rears, and if you go with fronts another $700.00
Tire sensors=$200.00
Mounting and balancing=$100.00
Post again if you need any more information, good luck AND YOU WILL NOT REGRET IT!!!
Old Oct 19, 2007 | 01:32 PM
SVT BAIT's Avatar
thanks for all the info i will be doing the rear conversattion plus wheels pretty soon
Old Oct 19, 2007 | 03:11 PM
SVT BAIT's Avatar
just got a quote for them from a buddy of mine at gm 965.69
