New to the Forum, 427 Swap
1. LS1 mod to 427
- Camshaft selections to stay within CA smog limits
- LS1edit baseline parameters for the 427
- What aftermarket TB is recommended/size
- Can stock injectors be retained or need to be replaced with what?
- Pitfalls to the swap to be aware of
- Does the engine exit the chassis from the top or bottom?
I race a Pontiac GTO and a 230 inch SC Dragster, all Pontiac powered,
so I'm ignorant to the LS1 and need some learn'in. thanks
1. LS1 mod to 427
I'm running a 242/242 on 114 LSA and I wouldn't be surprised if that passes. However, I haven't smogged this combo yet.
When you get the motor near the car I can help you. Need to know some particulars first.
Factory, ported, is fine.
No, you will need at least 30 lb'ers but I'd recommend larger.
The power upsets the balance of the car and you can look forward to a major upgrade in clutch, tires, brakes and suspension - oh, better consider tubbing and 18x12 wheels with the 330x18's you'll be adding
I've done it both ways but for me, the exiting the bottom was a more sanitatary swap.
