Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
would a 315 drag radial fit?
Old Nov 26, 2007 | 11:04 AM
SVT BAIT's Avatar
Default would a 315 drag radial fit?
Would a 315 bfg drag radial rub on my C6? Or would it fit on good with no issues
Old Nov 26, 2007 | 11:14 AM
ls1290's Avatar
Dumb Ass Vette Moderator
First I assume you are going to use a 18" wheel since I not aware of any 19" drag radial tires.
A 315 is ideal for a 11" wheel. Anything smaller will cause the tire to bluge and loose surface area on the tread. Some people mush them on a 10.5", but that is a mistake IMO.
If you are going to go for a 18" C6 rim, then go with a 275 wide tire or possibliy a 295.
Keith
Old Nov 26, 2007 | 04:38 PM
TXZ0603's Avatar
a Nitto DR will work just fine on a stock Z06 rear wheel. The BFG should be near the same
Old Nov 26, 2007 | 05:01 PM
dennis50nj's Avatar
18x9.5x 65 mm repro 295x35 x18 bfg drags 05 C6 A4 Z51 11.21 121.29 1.562 60 FT
