Need Help ,bad vibration in c5 rearend
The pop sound,...maybe be worn out tie rod ends... check those first.
The VIBRATION?...maybe it's a tire inbalance... like the wheel weight fell off? Or is the "vibration" really just a noise....translating through the car....
If it's a bearing...get in an area where you won't be arrested for swerving... and try some left and right manuvers... see if the noise goes away in either direction,...or gets worse.
Very hard to diagnose noise's or vibrations without seeing the car. This is coming from someone that uses chassis ears every day just about... so... hope any info helps.
best wishes.
Is the vibration speed related or constant after a certain rpm or mph ?
