Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
402 stokers??
Old Feb 6, 2008 | 12:34 AM
SVTBAIT's Avatar
Default 402 stokers??
do they consume alot of oil?? im going to forged and stroke my motor dont know how many cubes to go with what do u guys think? i heard the 402s eat up lots of oil?
Old Feb 10, 2008 | 10:13 PM
ls1290's Avatar
Dumb Ass Vette Moderator
As long as the rings are seated correctly during break in, you should not have any problems with oil consumption. There where some problems a while around with motors using a 4.125" stroke crank, 6.125" rods, and stock deck height blocks. The spacing/location of the rings in the piston is very important on these combos. The first ones of these had bad oil consumption problems, but since then the spacing issue has been figured out.
Keith
Old Feb 10, 2008 | 10:39 PM
Chicago Crew UnderBoss's Avatar
I agree if built professionally, balanced and blue printed, etc., with the right components, as long as its broken in properly should not have a problem, and great simple stroker to go with that makes great power (LS2 402, utilizing 4.00 crank)!
Old Feb 11, 2008 | 06:33 AM
WKMCD's Avatar
My 403 doesn't use or burn any oil at all. My shortblock is from SDPC. I broke it in exactly as they said using Rotel oil for the first 3k and changing it after 500/1500. I then switched to Vavoline Racing Oil (VR-1 Not for Street). Both oils are high in anti-scuff additives that are not found in many other oils. I'm now running synthetic. A well setup PCV system is essential.
