Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Antifreeze smell when AC is on...
Old Apr 16, 2008 | 09:05 PM
falconskaterjohn's Avatar
Default Antifreeze smell when AC is on...
I finally turned the AC on today and I smelt antifreeze through the vent. The car is running at a good temperature 220 max and all the other signs are good (no ses light). So I looked under the hood and could not see any leaks or anything. I am wondering if the guy I bought the car from spilled some antifreeze on some AC componets. Any suggestions on things I should check or should I just breath easy? Thanks for the help!
Old Apr 16, 2008 | 09:23 PM
gold98Z28's Avatar
heater core is leaking
Old Apr 16, 2008 | 09:42 PM
~JOSHUA's Avatar
You're f#cked...
heater core.
If you're good with a wrench then you're only sorta f#cked.... the heater core is the 1st thing bolted to the firewall.... everything else is piled on top.(Got...beer?)
Old Apr 16, 2008 | 10:14 PM
Alrighty thanks a lot guys but I was wondering why it only does it when the AC is on and not the heat?
Old Apr 19, 2008 | 09:48 PM
BlownVette 2001's Avatar
I would check carpet for dampness.
Old Apr 19, 2008 | 10:12 PM
NemeSS's Avatar
easy to bypass, if u are driving around it will eventually start leaking in your car, even with the ac off
