Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
tech: pin out question
Old May 26, 2008 | 08:12 PM
figgie's Avatar
Default tech: pin out question
Hi guys,
new user here!
Does any one have the schematics or pin out assignments for a DBW throttle pedal for a 2006 Corvette? I am looking for the down and dirty specifics
(looking at the connector with the locking tab on top)
pin A = 0v
Pin B = Signal
Pin C = 5v
Pin D = 5v
Pin E = - Signal (inverse of signal)
Pin F = 0V
Is this pin out correct or even close?
Any help would be greatly appreciated!
Old May 26, 2008 | 10:13 PM
figgie's Avatar
found the schematic!
The pin out for the ETC pedal is as follows for the curious (when reading the connector with the locking tab on top)!
Pin A = Low Ref (0 VDC)
Pin B = Signal (0% - 100%, this output is LOWER than pin E as there is an inline resistor that drops the voltage on Pin A)
Pin C = +5 VDC
Pin D = Low Ref (0 VDC)
Pin E = -Signal (0% - 100%)
Pin F = +5 VDC
this is extremly helpful if going "aftermarket" DBW!
Old Nov 23, 2008 | 01:57 AM
onefastrx7turbo's Avatar
Thanks!!
