charging system fault
I had the same warning on my c5 z06 and it ended up being loose and dirty wires at the starter comming from the battery.
You may want to check and clean all the grounds. Good luck
These also come with our latest billet piece....an overdrive pulley to match the rest of our pulley's.
$489 introductry price.
Here is a pic of the dash after 1 hr idle heat-soak:
