Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
C6 Z06 rear in a C5
Old Oct 7, 2008 | 11:42 PM
Paul418's Avatar
Have you considered going with an automatic? There were a few at the latest Z06fest. One in a TT and one in a 00 FRC that had gone through several rear ends and exploded a clutch. If you do go with the C6 rear consider a shield around your clutch because a clutch coming apart is a very dangerous thing and 1000hp is some serious power...
Old Oct 8, 2008 | 01:17 PM
ls1290's Avatar
Dumb Ass Vette Moderator
Originally Posted by JR-CRUZN-C5
Best: 9.44 E.T., 1.32 60', 148 MPH so far this year all in DA weather over 2200.
JR
JR, are you also running a FLP 4L60E or have you done the TH400 or 4L80E conversion?
Old Oct 11, 2008 | 10:25 PM
highpockets's Avatar
I am in complete agreement with you on the safety issue involved.I installed one of the first quicktime scattershields for C5s in my car.To date I have not exploded a rear diff but I am only cutting 1.69 sixtys.
Old Oct 11, 2008 | 11:50 PM
V-seriesTech's Avatar
Do the C6 swap....keep it a manual, throw on a kevlar blanket... and do it to it.
I plan on doing something like this at some point as well...but i'm more interested in the ZR1 ratios.
Old Oct 12, 2008 | 10:32 PM
Eric Hawkins's Avatar
I just ordered one of those for my car.
Old Oct 14, 2008 | 12:06 PM
obi-1's Avatar
I have one on my car. It's real nice. Has an aluminum plate to completely contain the clutch. Had to grind a little on the driver's side to fit the Kooks headers.
Old Oct 31, 2008 | 09:02 PM
I had to grind a little to get the bleeder to line up without putting pressure on the fitting.It seems like a very stout piece,and well worth the cost in the event the clutch decides its done playing this game ! Oh,and my swap is progressing nicely,here are a few pics for comparison sake.Here are the two housings side by side,C5Z and C6Z.
Old Oct 31, 2008 | 09:03 PM
And laying in front of them are their respective input/trans output shafts.See here for comparison.
Old Oct 31, 2008 | 11:33 PM
Z06PSI's Avatar
Torque tube stays the same?
Old Nov 1, 2008 | 08:25 PM
DLong's Avatar
Well my C6 Z06 rear swap is going to have to wait for awhile. I went to a track rental at MIR and one of my turbos ate itself. I figured it was a good chance to upgrade and pick up a new set. They are sweet with stainless turbine housings. Anyway they are borg warner from a non supporting vendor so I can't post a link. As luck would have it my clutch slipped big time for the first time. Now I am going to go to a twin disc. Needless to say my play money has run out for now. Can you just swap the trans output shaft on the 6 speed trans? I saw were you could do it on the auto.
Old Nov 2, 2008 | 06:16 AM
AU N EGL's Avatar
Rockland Standard Gear
Old Nov 2, 2008 | 03:42 PM
  #32
Yes,thats what I did.Also need the alum tailhousing to bolt to the new diff.Buy them new,they are fairly cheap.
Old Nov 2, 2008 | 09:56 PM
  #33
Here is a pic of the assembly,getting ready to go back in the car.
Old Nov 3, 2008 | 07:37 AM
  #34
DLong's Avatar
Thanks for the info. I can't wait to get mine started.
Old Nov 4, 2008 | 08:12 AM
  #35
Dragman's Avatar
wish I would have had one a few weeks ago!
not even counting broken tranny case and bent output shaft.
Attached Thumbnails C6 Z06 rear in a C5-vette002-1.jpg   C6 Z06 rear in a C5-vette003.jpg
Old Nov 4, 2008 | 11:36 AM
  #36
DLong's Avatar
Dragman that is exactly what I am trying to avoid. The way I see it, if you dragrace enough you will spend the money on a good setup or repairs.
Old Nov 4, 2008 | 11:51 AM
  #37
OutKlast's Avatar
Interesting. Is it really *that* much stronger?
Old Nov 4, 2008 | 12:25 PM
  #38
Dragman's Avatar
I did have 5 yrs of racing on that setup. I am going with C5 three rib case with DTE brace as my car only goes 10s.
Old Nov 4, 2008 | 11:19 PM
  #39
Too bad you didnt have the brace on it,it would have saved the trans case.Usually when it breaks like yours it bends/breaks the end of the output shaft regardless. Oh,and I can make you a deal on a clean output shaft and tailhousing for your trans.PM me if your interested,they are out and ready to ship !
Old Nov 5, 2008 | 07:58 AM
  #40
Dragman's Avatar
It did bend output shaft. I have already have parts to fix it, But thanks anyway!
