Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Updated seal for rear diff leaks.
Old Sep 10, 2003 | 09:20 AM
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
Default Updated seal for rear diff leaks.
Thanks to C5tech on Corvetteforum for this info.
Here is the document I received...It is a service bulletin review,not published yet,with out a TSB# issued to it yet (meaning hot off the press )
Service bulletin review
Service catergorie-Driveline/Axle seals to correct fluid leaks (w/diff) 14-leaks
Subj:Release of new rear axle seals to correct fluid leaks
Models:1997-2004 Corvettes
This bulletin is being issued to inform dealers that new and improved rear seals have been released for service for the above listed vehicles
Use the new output shaft oil seal P/N 88996703 and the new differential side cover o-ring P/N 89047953 when correcting rear axle leaks
Old Sep 11, 2003 | 09:32 AM
GREEN GOBLIN's Avatar
Default Re: Updated seal for rear diff leaks.
I believe this will give me enough reason to do the rear-end gear swap finally! "Hey, while your back there, here's a 3:90 gear..."
Old Sep 11, 2003 | 10:14 AM
J-Rod's Avatar
4.10 baby, all the way...
Old Sep 11, 2003 | 11:52 AM
66ImpalaLT1's Avatar
I've got a 4.10 rear end sitting in the garage waiting for a clutch to go with it. I bought it used and it doesnt look like it was leaking before.
Think I should throw these new seals on it just in case?
Eric
Old Sep 11, 2003 | 03:22 PM
What does everyone think of the 4:10? I've talked to many people around Atlanta and overall, the 3:90 seems to give great results.
Old Sep 11, 2003 | 07:13 PM
I had 4.10 in my 94 TA M6 and liked them a lot. It made 6th gear more usable. In my C5 they will be slightly less agressive since I'm using a 1" taller tire than I had in that car.
Eric
Old Sep 14, 2003 | 09:57 AM
U LUZ's Avatar
im putting a 3.90 in as we speak, i cant wait.......
