VERY dissapointing night....
2.97- 60ft
6.51- 330ft
8.71- 594ft
9.178 @ 95.51mph
Car was on low boost making around 580-600rwhp or so
Raceweight = 3900lbs with me in it- pure street car w/amps and sub
Crap 2-second burnout on worn out, 3yr old dry-rotted Nittos
Forgot to lower tire pressure so 30PSI of course!! (what I drove there on)
STOCK ten-bolt (ran out of money for now
) so I left very easyLoaded the clutch and left at 3500rpm
This was probably my 10th time going down the track. Last time was five years ago when the car was a 380rwhp cam only car so I was trying to take it easy for the first run. Didn't know it would be the only run.
I didn't think to feather the throttle and short-shifted first due to spinning. I spun all the way through second fishtailing WOT and spun halfway through third. Car definitely needs driver mod.
I was thinking though, even if I nailed some awesome 1.5 60ft, that would still put me in the 7.7 range? Thats horrible. I was expecting a 6.xx at 100+mph even with a crappy 1.9 60ft.
I did a full burnout the next time around on 14lbs of boost but the clutch bit the dust.
So next time: better burnout, better tires, use all of first gear, don't spin through second and third, and more boost.
If you make that much power, fix your car to handle the power before you hurt yourslef or someone else.
30th T/A:
You're absolutely right. I've been looking at a 2-step for weeks now. I would like to pick one up used though so I'll wait until I see a good deal.
What the hell does KY have to do with your comment?
Guy perhaps ran at Ohio Valley. It really doesn't matter - the vehicle went through tech. They don't ask if the clutch slips. They looked at the tires. Is your car legal to run 10's? You're running a 150 shot on a stock bottom end? That's sort of a time bomb in my mind.
I'll be coming from Ohio to The GREAT State up North Michigan this Friday. Visiting Milan again. Everyone I've met, even knowing I live in Ohio, has been friendly. What the hell is your problem?
If the NHRA and IHRA inspected every car as they should. You wouldn't be seeing too many cars on the track. Just for the hell of it since you run Nitrous. Do you show NOS on the back window? Do you have a NOS vent?
Ky driver, get a clutch and go racing again. Thanks for testing at the track!!
Yep mine is legal for 10s, been running a 150 shot since I bought the car new in 99 and the stock bottem end is doing just fine after 100+ bottles.
SStolen - Definetely sounds like a bad *** car! Just get a few things done to the car like you stated and keep banging gears with the rest of us 6-speed guys! Sounds like a little practice and you'll be all set. Sorry to come across so negative.
If you haven't found one already, it's not too late to get in on the super throw down Monster Clutch sale that ends this week
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
I think you're imagining a worse case scenario. I will be MUCH more selective when I choose my verbage on this site to describe anything next time around
. Take care. Are you powershifting? Helps a lot on any car, and even more on boost cars.
edit: I was thinking. I'll also drop my factory Z28 caback and just run open Y/cutouts. And I can switch out my heavy yellowtop battery and stock power driver seat for a lightweight battery and aluminum Kirkey racing seat my buddy has. Thats another easy 70-80 lbs so my car should be at least 200lbs lighter than the last run!!
