What should my trap speed be?
Old Apr 14, 2010 | 10:11 PM
Quick SSilver 98's Avatar
Default What should my trap speed be?
Ok first time to the track and I have never had the car on a dyno so I dont know the HP. My times were.
60ft---2.37
330ft---6.11
ET@594 ft--- 8.51
1/8 ET--- 9.04
1/8 MPH---- 84.1
1/4 ET--- 13.649
1/4 MPH--- 107.60
Well I could not hook for **** off the line (DUH LOL) and my 1-2 shift I spun really hard for at least a second and my 2-3 shifts I spun again but not near as bad, just enough to break the tires loose. I was on street tires at full weight. Say I put some MT drag radials and cut at least a 1.9 60 foot and not spin at all in my 1-2 or 2-3 shifts what should I trap. Car is a M6 with ls6 clutch in it and a formato tune other mods are in sig. Thanks
Old Apr 15, 2010 | 12:20 AM
WhitePhoenix99's Avatar
Your trap might increase slightly with a better 60' but it's your et that is really going to improve. You can count on around .2 off your et for every .1 off your 60'. So if you get the 1.9 you are saying you should be SOLIDLY in the 12's. The tires you're gettin should get you there
Old Apr 15, 2010 | 05:58 AM
69LT1Bird's Avatar
The trap speed could go down slightly (bog, pulling motor down). Without the spinning off the line, the RPM's will be lower which will net you less RPM's at the line.
Only Horsepower will increase the trap speeds. Traction will lower ET.
Old Apr 15, 2010 | 01:45 PM
2000SS1979's Avatar
Put some stickies on that car and it will do 12.8's @ 108 all day.
Now with me driving probably more like 12.5's @ 108 all day.
Old Apr 15, 2010 | 01:52 PM
haha maybe if i cant run better than a 12.8 I will let you take it down the track to see what she can really do.
