Almost got a 9sec Pass
Probably had the fastest car at Mayhem but took second in the shootout since I forgot to turn on the N2O and short shifted 3rd gear since the previous run it was slick down track and I got loose in 3rd. Oh well it was still a great night of racing.
First Pass - 150 Motor HP Jets (62/33) FJO 30-100% 1.0s
60 - 1.392
330 - 4.261
660 - 6.603 / 105.31
1000 - 8.568
1320 - 10.216 / 135.13
Second Pass - 150 Motor HP Jets (62/33) FJO 30-100% 0.7s
60 - 1.431
330 - 4.187
660 - 6.459 / 108.84
1000 - 8.382
1320 - 10.015 / 136.17
Third Pass - 150 Motor HP Jets (62/33) FJO 35-100% 0.7s
60 - 1.320
330 - 4.125
660 - 6.434 / 106.87
1000 - 8.378
1320 - 10.007 / 137.29
Forth Pass - 150 Motor HP Jets (62/33) FJO 32-100% 0.5s
60 - 1.357
330 - 4.125
1000 - 8.388
1320 - 10.011 / 138.27
Fifth Pass - 150 Motor HP Jets (62/33) FJO 40-100% 0.5s
60 - 1.318
330 - 4.113
660 - 6.544 / 99.06 (Slick down track - peddled 3rd)
1000 - 8.648
1320 - 10.351 / 133.62
http://www.youtube.com/watch?v=twDytooHs54
http://www.youtube.com/watch?v=dMJHfj-9FQ4
wait 1st i thought this was laura, but maybe not. i htink i meet you at the shootout if it is. ashlys ta is white, and michells is/was green.
Do you have a diagram on how you wired the 2-step/controller up? Im in the process of wiring up a controller as well, I want to make sure it doesn't activate while on the two step.
The clutch is a spec 3+ with a billet flywheel, GM slave and the Tick Adjustable Master Cylinder
Front suspension is stock except for QA1R's (set on 4) and Strange Race Brakes, MT Front Runners
Rear Suspension is a MWC 9", MWC TA (Top Hole in Front), MWC LCA's (2nd Hole From Bottom? Might be 3rd), MWC PHR, QA1's (L6/R10 - I need a drag bar), Strange Race Brakes, 28x10.5x15 MT ET Drag
I attached a diagram of how I hooked up my FJO Controller and the Lingenfelter 2-Step For the 2-Step I rewired the clutch switch per their instructions for a +12V activation to the 2-Step. I then hooked that up to the FJO second input configured for +12V and it disables the N2O stage(s).
Thanks, still trying to go fast on a T56, all my friends want me to put a 400 in it and I almost did last year when I miss shifted 3-2 twice and bent valves each time.
Nope don't think we've met, my name is Greg and I wasn't at last years shootout, should be at this years though.
