Stock internal 6speed, New best 11.4183 at 117.8 Da was around 1150, these were back to back passes. Went out there not expecting to get a new best 1.5664 60ft 4.6799 330ft 7.2928 1/8th 93.83 1/8th 11.4442 1/4 118.64 1/4 1.5370 60ft 4.6540 330ft 7.2854 1/8th 93.42 1/8th 11.4610 1/4 117.59 1/4 best 60ft was 1.5237 best before was 1.54, Installed the MWC drag bar for the track that day so it helped some. Update 10-28-2012 Da 762 1.5606 60ft 4.6412 330ft 7.2532 1/8th 94.30 1/8th 11.4183 1/4 117.80 1/4 was on a pass when i tried to shift too quick into 4th. Compare the 330ft to the one above. da 700 1.5341 60ft 4.6059 330ft 7.2965 1/8th 90.54 1/8th 11.5676 1/4 115.80 1/4 Could have probably ran faster later on, the da was down to 116ft when i left. |
Nice congrads man. That thing is moving for stock internal |
Very nice! Impressive for sure |
nice work , I think if you look at the stock internals top 50 list you will be atthe top or 2nd for 6 speed cars , I know the top car was in the 11.4's last I looked |
Raceweight? |
Nice, also like to know race weight |
Good job! |
My bad i forgot to put the raceweight. I would like to say it is between 3300 and 3350. Last time i weighed it was at 3590 last year, took about 250lbs out of it. Will have to add it all up. It has more in it, the brakes drag really bad so gonna fix that. The tune might have a little more in it. Taking about 20 or more lbs out of it. Temp was only like 64 degrees. Gonna try a few things with the suspension and tire pressure. Thanks guys, will have some new times when it gets cool out. |
congrats!!! |
Damn, I had to do a small cam and milled 243s to get into the 11s, lol! Very impressive man! |
Originally Posted by nmass399
(Post 16840798)
Originally Posted by flintwrench69
(Post 16853574)
Is that 3300 with you in the car? Seems like that car would have to be really light to run the times it does. Ive tried to get the most out of it over the years. It would be even faster without this heavy roll cage i have lol. |
Great job killer! |
Congrats! I knew you and the car had the potential to be the S.I. 6spd reacord breaker :cheers: |
Great ET for the MPH in a 6 speed. Awesome driving. |
Thanks everyone, i still want more tho lol. I am working on figuring the tune out some more and seeing if i can get back to no lift shifting this joker. I think once i adjust the clutch pedal back down some where it releases right off the floor i will be able to shift properly. |
Rolling out for a bolt on 6 speed for sure. What track you running at, Hub City? |
Originally Posted by Tweek
(Post 16862952)
© 2024 MH Sub I, LLC dba Internet Brands
