need help at track
Seems that you are down on power for some reason. Has the car had its plugs and wires changed any time recently? Just wondering why it doesn't trap higher mph? DA should not have been too terrible at that temp even with higher humidity, not idea but definantly not killing you too bad.
Always make sure you are getting 100% throttle opening ( make aure floormat is not getting under pedal} and see where your shifts are taking place( hopefully around 5800-6000 rpms. Make sure your not letting up on the throttle any at all.
I could see losing some performance with close to 200K miles, but I think you may have some other factors going on.
Good luck with your next outing.
