Help!! No speed increase!!
Thanks in advance....
The trap does seem low , both of my bolt on cars trapped in the 111/112 range and ran 11.9/12.1 respectively but also were both run in negative DA's with 1.7 60 foots for both.
You can search da calculator and some of them even let you select your track , date and time and spit out what the da was , DA can account for several MPH but I think theres more than just that going on... can you post all the info from a couple of your passes so we can look at what happened ?
103/104 trap in a 6 speed car with stock 342 gearing should be going through the traps about to tickle the rev limiter in 3rd gear depending on where your tuner has the limiter set at- did you shift into 4th ? if yes slightly taller tire and slightly increased shift rpm's may gain you a couple mph but after that your going to need 4th gear as you surpass 105 trap. A shift light can help a lot too to wring out every gear consistently and avoid both short shifting and bumping the limiter hard
R/T...1.041 0.551 0.688
60'....2.383 2.584 2.630
330...6.203 6.581 6.594
1/8....9.209 9.717 9.673
MPH...82.08 74.23 80.69
1000..11.763 12.586 12.258
1/4....13.908 14.875 14.415
MPH...103.95 99.75 103.21
Sorry for the mess it doesn't show like it was typed...
Any and all help is appreciated...
how about the most basic stuff like fresh properly gapped spark plugs , new fuel filter , clean air filter , no blockage in intake tract?? ( I sucked up a plastic bag once and it slowed a car down like that)
and you added a ported throttle body in your list of mods verify that it is opening to full throttle.
how about fuel quality ? a couple gallons of unleaded race fuel on top of a low tank is always a good guarantee your not getting any KR which will pull timing=lost power
the mods you added will make your car much quicker than it was you just need to isolate what is causing it to be down on power likely something very basic
I also checked and last years 60 ft times are pretty consistent with this years...
