Stock C5 on Runflats
BTW what rpms did you launch at, and did you dump the clutch????
60' 2.022 Stock run flats
330 5.514
1/8 8.353
86.94
I bring it up to around 3000 and let the clutch out fairly quick(not a clutch drop) Once the clutch is out I roll the throttle on. Do not give it anymore throttle till the car has launched and the weight has transfered. Experiment with the launch rpm and remember no more throttle till the clutch is out. Good luck and have fun.
When I ran my 13.6, it was my first time racing the car, and I had 2.2 60' times and it was pretty hot. I've since then put in new plugs and wires. I also just ordered a vararam intake and I'm about to order the ls6 intake manifold and Borla Stingers. Hopin' that those two mods will put me down to a 13.3 - 13.4 especially with fall approaching.
