First time at the track.help with launching
I control my clutch/tirespin to cut mid 1.7 60' times on DRs with a stock 10 bolt and LS6 clutch, and I leave usually above 5000 rpm to get it to work right (with 4.10's).
The key to the clutch slippage is to just slip it just enough to take the shock off the drivetrain. On my car.. it almost sounds like I dump the clutch.. you will know if you did it too fast or too low because the car will most likely spin or bog.
