Just tracked the ECS paxton..130MPH!!
So it was way fun.
No problems. Started the 1st run...13.0@120mph
Finally got consistant and was running 12.4@123mph spinning the tires 1st-3rd gear(track sucked). By the 4th run I finally looked over at the boost guage and I was only running 6.5-7psi of boost
I was seeing 10psi on 60deg days. Today was 84degs out 70% humidity(nasty conditions). So I removed the restrictor plate and now I'm seeing 10-11psi
Next 2 runs I trapped 130mph with a best of 11.6 sec with a 2.2 sec 60ft. Still spinning the street tires 1st through 3rd gear. I'm running 14degs timing and 10.6/1 AFRs. I just need to practice and get some better tires. The 19"wheels are not helping me any either
Got whipped by a guy in a 2002 Z06 with a built 402LS2, 100hp shot NOS, line lock and drag radials.... But only by .2 secs
....He traped 136mph and hit the NOS in 3rd and 4th gear.............He freaked when I told him it was stock heads and bottom...
It was nice to meet you last night. Im sure if Gus's LS2 402 would have hooked it would have been ugly. Ive helped build that car and it totally raped a 402 stroker with a D1SC. Your car is running awesome. Forge the motor so you dont have to worry about it
