Heading to the track again this afternoon
60' 1.658
330' 4.916
660' 7.700
MPH 87.981
60' 1.695
330' 4.938
660' 7.711
MPH 88.311
60' 1.681
330' 4.925
660' 7.721
MPH 87.939
Looks like I ought to be bracket racing this car, huh?
This was with the 26 x 9.5 x 16 Hoosier QTP's on stock salad shooters and not the MT Street Radials on the Bogarts. I was trying to take wheelspin out of the equation so I could compare apples to apples performance wise. It looks like the weight removal just about exactly offset the worse air running only a tad slower MPH and being off the pace less than a tenth. My chromoly (sp) K-member showed up today
and I should be getting the chromoly upper and lower A-arms within the next 30 days. I know they don't make these anymore but I picked up a set and I truly feel fortunate to have been at the right place at the right time to get them. I'm also getting some 15 x 4 Welded RT Bogarts up from to match the rears I have along with some Strange drag brakes. Carpet's coming out along with the console to be replaced with the drag race carpet and shifter. I wasn't going to do that but after looking at the pics of Nine Ball's interior I have to try it. His car was/is an inspiration to me it looked so clean and professionally done. All in all another 250 pounds is coming off the car by about July. It looks like I'm going to keep plugging along with my SI combo trying to get on the SI list in 90+ degree heat and 3000+ DA air. I want to get the car under 3000 pounds before the heavy iron block 408 goes in. Oh yeah, this was through the mufflers tonight and not running open headers like normal. The 7.64's last time out were through the mufflers also so I kept them on tonight to take out that variable. I probably won't be hitting the track again until I either take some more weight off the car or get someone a couple of hundred pounds lighter to drive the car to see if that makes a difference. Thanks for reading. I just feel like sharing info when I have it to share.Launch pic. Hope it works.
