I love da 2-step
Not really much to say about last night, my first 3 runs my shiftlight wasnt working (ground wire came undone under the dash, fixed it), 1st and 3rd run the 2step didnt engage cuz the clutch wasnt down all the way. But the 2 times it DID work (2nd and 4th run) it was awesome. SO much more consistant and takes the guesswork out of pedaling the throttle out of the hole.
With the 2-step set at 4800rpm,
2nd run 60'=1.61 (then I missed 4th gear)
4th run 60'=1.58 New Best 60! Shiftlight was working and went 11.76@118. Not really ideal racing weather, but w/e.
Now that I got the launch down, expect some new bests this fall
To compare, my 11.58@120 run was with a 1.69 60'. Doing a little math if I can pull a 1.58 again in the fall I should be able to drop another .15 off my 1/4.
To compare, my 11.58@120 run was with a 1.69 60'. Doing a little math if I can pull a 1.58 again in the fall I should be able to drop another .15 off my 1/4. Last edited by RaNsOm; Jul 29, 2006 at 07:59 AM.
congrads...what is the info on the two step, manufacturer how much, did you do the install your self...if so how hard was it...i have been thinking about going that way jus not sure about it yet .....wellsee
how complex is the wiring and install, i havent ever been much of an elextricain but i dont like having others do it i would rather learn and do it myself thansk ransom i appreciate it!!!!
