first run
my fastest was only a 13.93
though any advise on how to go faster. i have a 99 trans am a4 with catback, filter and a lid, and descreened mass air with stock 2.73 gears. i dont want to rally spened alot of cash and really cant mod to much because i have a warranty. any help would be aprieciated.my reaction time sucked buthere are the numbers for my runs
first run let off at 1000ft was told if i went faster than 13.99 they would shut me down(forgot my helmet).temp was in the 80's and there was a head wind that started to get worse id say 20mph or more at the end
reaction0.1429
60ft 2.16
330ft 0.0070(?)
1/8 9.0950
mph 79.79
1/4 14.53
mph80.23
second run
0.2382
2.1927
6.0690
9.1857
79.49
11.8189(1000ft)
14.0207
102.51
3rd run
0.525
no 60ft
6.0380
9.1299
80.35
11.7378
13.94
101.53
4th run
0.5719
2.11
9.0631
78.94
13.9352
100.89
Try again when the temps are a little cooler and headwind is minimal or non-existent. If you still can barely break out of the 14's then I would strongly consider saving for a dyno-tune. If your a/f ratio is out of whack for whatever reason then you could be losing a lot of HP. Not to mention that running too lean or too rich can be dangerous to the motor.
Good luck on your next track day.
