Help Me Get 10s!!
Old Aug 11, 2007 | 01:02 AM
Jeenis's Avatar
Default Help Me Get 10s!!
Alright, here's my best time slip from tonight. with my trap speed, i should be in the 10s right? it's a decent 60', not great, but ok. btw, i'm soo happy they didn't mention roll cage with that ET, the track was shuttin down, so i don't think they cared.
60' 1.86
1/8 7.41 @ 101.2
1/4 11.32 @ 128.5
conditions were 91 degrees, running BFGs at 14psi, rwhp 562
(previous best -before h/c work was 60' 1.73, 1/4 11.25 @123.2)
thanks for any suggestions!
Old Aug 11, 2007 | 02:30 PM
venom ws7's Avatar
Man you really should talk to Ranger with hp you got 10.5 and 130mph shouldnt be a problem.
You ran 11.2 with boltons right? what 480rwhp?
Good burnout 3000rpm and slowly slip the clutch but dont let it bog of the line.
Good luck and you have one awesome car man congrats.
Old Aug 11, 2007 | 03:11 PM
Magnet's Avatar
yea i would talk to ranger he went 10's stock
Old Aug 11, 2007 | 04:32 PM
z28poweredlt1's Avatar
You'll have it with a little help on that 60'
What gears and what size wheels//tires are you running?
Old Aug 11, 2007 | 06:28 PM
Jeenis's Avatar
i figured its gonna be the launch. i'm running 315/35/17s on back, stock gearing (i think its 3.63?). my 1/8 and 1/4 speeds are fine, just not the time behind em. i guess it's that launch. next friday yall, 10s here i come!
Old Aug 11, 2007 | 07:27 PM
4.10's might help your 60' if you can get teh car to hook, are you bogging or spinning really bad?
Old Aug 11, 2007 | 07:30 PM
10's stock in an f-body or zo6?
Old Aug 11, 2007 | 08:16 PM
Matt D's Avatar
Retired Street Racer
That is definitely a mid to high ten if you could hook it. The 60' is high due what looks like too much heat and lack of a sticky tire. You're picking up pretty good from the 1/8 to 1/4, just get it to hook.
Old Aug 11, 2007 | 09:42 PM
Jeenis's Avatar
ranger was 10.85 stock C6Z with DRs. granted that dude is incredible driver and had the DA in his favor.
in working on the launch, i'm launching at 5000 rpms. when i get a good burnout, it hooks fine, but it still bogs down a bit, till about 4000. should i launch at higher rpm? that seems a bit high as it is, and i redline at 7.
Old Aug 11, 2007 | 10:20 PM
matt94z's Avatar
Keep raising your launch rpm until you slightly spin. Bogging is killing your time.
Old Aug 12, 2007 | 01:58 AM
I think you'll get it with a little more track time dude, you're very close and your MPH is def there, Keep up the clutch work, if you're bogging, you need less clutch or more throttle. If you're just strait dumping, add some feather to it.
Old Aug 14, 2007 | 02:04 PM
WHPLASH's Avatar
Try to get someone to video tape your runs. I'd love to see that thing going down the track!!! Then we can see your launch. Your 60' times are fair.
Nice car!!!
Old Aug 17, 2007 | 09:30 AM
Jeenis's Avatar
Nice car!!!
not to resurrect an old thread, but heres that video
(i'm going to Ennis tonight, if i make 10 sec club, i will shout it from the rooftops here ) i've gotten a few pointers, maybe yall can add more. i'm gonna run my DRs 18psi hot and launch a little lower around 4200.
Old Aug 17, 2007 | 12:18 PM
Demonicbird00's Avatar
your def losing alot in the first 1/8. since you have so much power you can see that your whole time is made up on the back half.
i went 7.071 @ 98.06 and went 10.998 @ 126.93
try coming out of the whole a lil higher on the launch.
the weather isnt helping you any either. come fall youll def run 10s!!
heres a site that i use prior to heading to the track to give me an estimate of the DA.
http://wahiduddin.net/calc/calc_da.htm
hope that helps.
good luck
brandon
Old Aug 17, 2007 | 12:47 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
You need a 7.0 - 7.2 in the 1/8th to run 10's at that mph, you need to get the car faster in the first 330 feet.
Old Aug 17, 2007 | 12:51 PM
4yall2nv's Avatar
its definetly ur launch, it seems u bog and never get out of the hole, but after that that car is movin! good shiftin 2!
Old Aug 17, 2007 | 01:36 PM
+1 for that first 300 Feet
