horrible et's !!!!
Old Apr 7, 2008 | 03:34 PM
keithystealmaro's Avatar
Default horrible et's !!!!
ah the first time i took my 2000 black ss to the track m6 with 115k on her and the first time down i got a 16 second pass i missed 3rd gear!! then second time down i got a 15 flat sec pass at 95mph
Old Apr 7, 2008 | 03:43 PM
Wsteun's Avatar
Something is wrong with your car. Are you up to date on all of your maintenance?
Old Apr 7, 2008 | 04:52 PM
yea and my car only dynoed 280 at the wheels a m6! well my head melted on my block not too long ago so i had that done and it hasnt been tuned... do you think i need to get it tuned because my head melted on my block?
Old Apr 7, 2008 | 04:54 PM
bjamick's Avatar
Ok, are the heads sealing against the block??
Old Apr 7, 2008 | 05:03 PM
sorry to sound like an idiot but u do not know what that means " are the heads sealing against the block" ?
Old Apr 8, 2008 | 09:08 AM
bjamick's Avatar
You said the heads melted on the block, correct? Im guessing you prob had the heads milled or something along those lines, correct? Or did you just buy a new set of heads?
If the heads aren't sealing onto the block, I would guess your losing compression bc of it, which would cause and issue. I would just hope that the head gasket will keep water from getting into the cylinder.. Not for sure if this is your issue or not.
Old Apr 12, 2008 | 09:29 PM
yea i just head them milled it cost like 1300 to do.
Old Apr 13, 2008 | 08:33 AM
Duffster's Avatar
For 1300, you could have had Stage 2 heads installed.
Old Apr 21, 2008 | 08:01 PM
i am going to the track again tomorrow hopefully i can produce some better times!
Old May 9, 2008 | 10:53 PM
MY99TAWS6's Avatar
My near stock 96z runs 14.2 at 96mph with shot plugs. You should be doing 13s for sure at pretty far over 100mph. You are down like 100 horses. Unless your track is much higher than ours. Ours is 1600 feet above sea level. Most stock six speeds here are running like 13.7 ish. Talking the heavier tas. The lighter z28s and SS are usually like 13.5.You have serious issues with your car. If the engine is good your clutch is likely finished.
Check compression maybe leakdown if compression is bad. Any check engine lights?
Change fuel filter, plugs, mabye badly clogged cats? Bad fuel pump. something is killing your mph and your et. Mph shows true power best though. Et can be driving and traction.
