pinion angle question For a T400 NEED HELP
Here are my measurments. this car mostly sees the track
driveshaft end +1
bottom of driveshaft where the ujoints are the flat part +0.5
bottom of the T.A plate that bolts to the tranny -2
bottom of the rearend towar the back -3
any help would be great. also when tunning the car and driving it around there is a whinning noise comming from the rear. I check the grease and all is fine in the pumpkin. its only driving slow or turning. mostly turning. any ideas. I had a new steel driveshavt made. and the rear is a moser spool 12 bolt
Measure your tailshaft angle on the transmission. For example let's say it's pointing down 2 degrees. Now set the pinion angle so after it rotates upward under power (generally moves up 2 degrees) the ujoints will be aligned. So -2 down tran = 0 degrees pinion so they are level under power. If the trans = -1 degree down, set the pinion -1 down so it will be +1 under power. If the trans is -3 down, set the pinion +1 degree up so it will be +3 degrees under power.....etc....etc.
Only time you would set the pinion angle down - 2 degrees, is if the trans is at 0 degrees.
