Next suspension mod?
Here is my current set up:
Stock LS1-Heads/cam/420 rwhp, Vig 3600 & 3.73s
! Front sway bar
! Spare & jack
BMR lowering springs
BMR tubular LCAs & relocation brackets
UMI subframe connectors
Stock shocks & all other suspension not listed.
Bogarts-Morosos on the front & 275-50-15 MT ET radials on the rear
Car was right around 3500 lbs with the stock wheels on it, never scaled it with Bogarts on it.
Have went a best 60' of 1.51 a few times & all of my other runs with this set up have been in the 1.5s.
Here is a launch picture-
http://www.1320video.com/gallery/Mid...out08/IMG_9576
Any thoughts are appreciated.
Jason
It looks like the chassis is twisting in the pic (LF higher than the RF). I would get a rear drag sway bar (to help straighten the car at launch) and front QA1's to help with weight transfer. I didn't see a mention of an aftermarket torque arm, I would get one of those as well.
Thanks for the advice. I have thought about a tq arm, but didn't know if it would help me go faster.
http://www.bmrfabrication.com/F4.htm
Right now we're offering an end of race season discount as well which is on the site. Thanks and let us know if there is anything we could do for you.
I do recommend a torque arm as one of your next modifications, the QA1 shocks are a good idea as well and we carry those.
if you have any questions please give us a call.
Thank you!
Ryan
Qa1's will work, but we have had good luck with the cheap Comp Engineering rears as well.
I have the BMR drag bar on my car and it leaves straight and everyone always comments about that. The TRZ bolt in anti-roll bar is some pimp **** and we have that on Z8's car. I run the Spohn bolt in 1" on my fathers car and it has worked well too.
I would get some front Strange or Qa1's to set it off.
so in simple form torque arm, rear shocks and a rear bar and if the budget allows front struts.. let me know what you chose and when you are ready
