Drag Racing Tech
how much would this project cost?
Old Oct 23, 2008 | 02:32 PM
z28rob18's Avatar
Default how much would this project cost?
i just am asking because my dad put the idea in my head. wat would it cost to set up a 98 v6 camaro as a drag car. the motor would be a carbed 350 runnin on nitrous probably a big shot. hav everything to build the moter already the block just needs to be freshened up. the car would be stripped of everything need a trans and a rear to take the abuse wat else and how much would u say total if the goal was 9.90-10.1?
Old Oct 23, 2008 | 04:00 PM
Z06PSI's Avatar
PM black8banger as he did this.
Old Oct 23, 2008 | 06:01 PM
Camaro396's Avatar
Well suspension/drivetrain wise, will be the same as any other LS1 or V8 F-Body, as you will be using the same parts....the only thing that would be diff is instead of modding a LS based motor you would be starting from scratch with your SBC.
Old Oct 24, 2008 | 08:45 AM
wlsmoku's Avatar
i'd guess 12-15k would be reasonable just depending on if you bought new/used. hell even wheels can vary a shet ton in price.
rearend - 2,500
driveshaft - $300
control arms - 250
panhard - 180
anti roll bar - 450
torque arm - 420
driveshaft loop - 100
subframe connectors - 170
qa1 shocks - 450
k member - 500
lower a arms - 450
conversion cross member for turbo 350/400 - 180
10 pt wolfe cage (jig notched) - 1000
turbo 400 - 800
shifter - 150
nitrous - 1000(just depends on what you go with)
kirkey seats w/covers - 450
5 point harness - 80
roll bar padding - 40
line lock - 150
bigger fuel pump - 200
poly motor mounts - 75
total so far - $9900
which doesn't include:
some type of ignition box
distributor
intake
carb
elec water pump
wires
plugs
headers
extensions/turn downs
motor refresh
cam
stall converter
then figure another 700 in nickel and dime stuff (ie return line, over flow bottles, anti freeze, oil, etc)
and i'm sure i'm forgetting stuff
Old Oct 24, 2008 | 08:53 AM
mad_steve's Avatar
I can get you a quote worked up for all of our suspension parts (i.e. torque arm, lca's, panhard rod, shocks, etc). Call me at the shop if you're interested. We give a 10% discount to anyone that buys a full suspension package from us. Shop phone number is 225-673-3533.
Old Oct 24, 2008 | 09:15 AM
z28rob18's Avatar
thanx everyone and thanx for the offer madman but as of right now its just an idea i still hav a car that i drive around everyday that im workin on but if i do ill call u up heard great things about u guys
Old Oct 24, 2008 | 09:35 AM
mad_steve's Avatar
That is ok. Whenever you're ready, just give us a call. We definitely aren't goin anywhere anytime soon. lol.
