Need idea of possible times with changes...
My best was: (Temp and humidity in upper 70's. Barometer was 29.25. Track elevation is 1000 feet.)
60' 2.4
330' 5.914
1/8' 8.721
MPH 87.61
1000 11.11
1/4 13.09
MPH 115.25
As you can see I spun like hell with most 60's in the 2.5+ range. This was on 17" Nittos and a 2500 RPM clutch drop with the T56. The car went sideways off the line each time after it went sideways I had to back off and get on it again.
The car THEN had stock suspinsion with 3.42's in a 10 bolt a raceweight of 3675 and 425/409 at the wheels.
The car NOW has a racewight of 3490, 4.11's in a Strange 12 bolt, same power, Full BMR suspinsion with relocation brackets, -2* pinion angle, 26x11.5x16 ET streets, and skinnies up front.
Could anyone make a guess as to where I should be now? I dumped a ton of money into the car and want to see the fruits of my labor.
Im guessing atleast high 11's in the same weather if I can pull a 1.7 60'. Does this sound right?
