Drag Racing Tech
need help with front brakes
Old Oct 25, 2008 | 08:04 PM
kentuck's Avatar
Default need help with front brakes
2002 camaro need info can i put smaller brakes off a 93 on the front the front brakes will not take a 15 inch welld rim the 93 camaro brakes are smaller will they bolt on ??
Old Oct 25, 2008 | 08:11 PM
daniel6718's Avatar
you have to grind them....93 arent an smaller at least if they are its not worth the time for the small differance...but yes 93 will fit
Old Oct 25, 2008 | 08:47 PM
DMH Fabrication's Avatar
You can run a small spacer or clearance the calipers to get the front rims to clear the ls1 brakes. If you swap to LT1 brakes you have to have the entire LT1 spindle and brake set up to put on the car.
Old Oct 25, 2008 | 09:00 PM
9sec93's Avatar
yes as stated above, you have to change the whole spindle.
Old Oct 26, 2008 | 09:17 AM
Steve Burger's Avatar
LS1TECH Sponsor
Drag brakes, Grind, or run a spacer.
