Drag Racing Tech
15" ProStar grinding question
Old Sep 18, 2003 | 05:33 PM
Tally TransAm's Avatar
Default 15" ProStar grinding question
im probably getting a set of prostars, 15x3.5 and 15x8.
i REALLY wanna set what they look like on my car before i get them though. can i get them on my car to look at without grinding the calipers first. i know i have to grind the calipers down to make the rotate but will they just go on for appearance purposes without grinding
also anyone have pics of a grinded caliper so i know where to start
thanks
ryan
Old Sep 18, 2003 | 06:27 PM
B18B1LS1's Avatar
Default Re: 15
They will go on enough to sit there, but not enough to tighten them down. At least mine wouldn't. But you can get the idea I guess if that's all you want. I'm sure you could find a pic of someone else's car with those wheels though, they are pretty common. Good luck!
Jeffrey
Old Sep 18, 2003 | 07:06 PM
Default Re: 15
yeah but i need to see it im person before i decide to spend the money one them
Old Sep 19, 2003 | 12:15 PM
Roadrunner 45's Avatar
Default Re: 15
With the longer studs I put on, I could set the wheels on the car- but there's no way you can tighten them down. You could raise the car on jackstands (jackstands under the suspension so that the wheels sit at the normal position in the wheelwells) and set them on to see what it's gonna look like, but there's no way you'll be able to lower the car down without grinding or putting in a HUGE spacer- probable more than 1/2" on the rears (even then, you won't have enough thread engagement to really tighten the lugs).
