Drag Racing Tech
View Poll Results: Best shock for drag racing only car?
AFCO
56.92%
QA1
32.31%
Strange
10.77%
Voters: 65. You may not vote on this poll
Which shocks are best for drag racing?
Old Nov 10, 2008 | 10:13 AM
fasttagurl's Avatar
Question Which shocks are best for drag racing?
What is your experience with these shocks (double adj.) and post pics if you got 'em shown with how they look on launch and/or going down the track. What TA do you run (shorter or regular length) and how much did a drag-launch "anti-roll" bar (rear) help you if you got one?
Afco
QA1
Strange
Old Nov 10, 2008 | 10:40 AM
GregWS6&z28's Avatar
Afco's are the best but most expensive (offer you more adjustment options)
Qa1's get it done if you only need single adjustable (for double adj. may as well go Strange or afco)
The Stranges run just a smidgin more than qa1's but seem to work better for single adjustable.
Qa1's are most popular since they are cheaper.
Old Nov 10, 2008 | 11:01 AM
ty_ty13's Avatar
7 Second Club
afco#1
strange#2
Qa1#3
in accordance to the selection you listed
Old Nov 10, 2008 | 11:18 AM
BMR Tech's Avatar
Money being no option the Afco shocks with Strange coming in second. I have customer cars well into the single digit zone on both.
We are also a distributor for both brands.
Old Nov 10, 2008 | 11:38 AM
Steve Burger's Avatar
LS1TECH Sponsor
AFCO is by far the best. The other 2 are never at the track with the capacity to rebuild, revalve, or dyno a shock. AFCO is at most of the major races and can do this. They are not that much more than the QA1 or Strange DA shocks either.
As for a TA, short is better. A short adjustable is even better.
The point of the Anti Roll Bar is dead level launch. From your description on the phone it would help. At a minimum, you need a BMR Extreem Drag sway bar. I think you are at the Anti Roll Bar point.
Old Nov 10, 2008 | 12:01 PM
BlackScreaminMachine's Avatar
Internet Mechanic
As far as opinion, neither are a bad choice, AFCO seems to be the **** compariatively.
I have a car hear with single adjustible QA1's running 1.3's in the 60 all day and no signs of needing a rebuild has to have over 100 passes at the track and some 1000 street miles.
I personally will be getting the QA1 for my street car.
For a track only car, race wolfecraft makes a quality bar but not intended at all for the street, I personally will be getting Spohn's largest swaybar that uses the poly end links. Just because I do want to corner.
Old Nov 10, 2008 | 09:02 PM
NHRAFORMULA00's Avatar
Most people just follow the leader here on this board by going with Qa1.I went with the Strange DA up front because i know that the name is Quality products.I also have a SPOHN drag sway bar in the back, and the difference is night and day now,car leaves nice and level. Adjustable TA,long.I also cut the rear springs 1 1/2 to lower the rear,still on stock rear shocks(not for long) and i have gone a best of 1.37 60 ft,with this combo.
Old Nov 10, 2008 | 10:51 PM
car_fixer's Avatar
My first choice would be the afco's, but, I would ask what your goals are with the car, it is pretty respectable as it sits. I am sure you could benefit from a anti roll bar, especially with a torque arm car. It will help alot at the track, but if it is street driven it could be a serious problem as it would cause the car to be very tail happy, usually when you least expect it.
I use a stock length torque arm, with a anti roll bar I built and 60 foot mid 1.2's so take that how ever you want, but it works well.
Old Nov 10, 2008 | 10:54 PM
Fast_94_Z's Avatar
personally afcos. ive seen the best performance results out of afcos and theres numerous things you can adjust. strange follows second for me.
Old Nov 10, 2008 | 11:11 PM
DMH Fabrication's Avatar
Depending on what you want to spend...Santhuff #1, Afco #2, Strange #3
Old Nov 11, 2008 | 04:18 PM
WS6 Rampage's Avatar
From: The dirty taint of the country. ...Los Angeles
How much are the Afco's going for?
Old Nov 11, 2008 | 04:22 PM
fasttagurl's Avatar
I got a quote for $1600 for all 4. ($400 each)
Old Nov 11, 2008 | 06:08 PM
Sideways240sx's Avatar
Afco are the best. Strange are the best bang for the buck. I picked up strange for my car.
Chris
Old Nov 11, 2008 | 07:19 PM
tektrans's Avatar
I have QA1's all around. Been in the car for years, hundreds of passes and thousands of street miles-no problem, no rebuilds.
Stock lenght ta for me. Spohn bar.
Old Nov 12, 2008 | 11:35 AM
thechef's Avatar
Moderator
Full Race Car....AFCOs
Street Strip Car.....HALS QA1
Old Nov 12, 2008 | 03:17 PM
Coach 02 A3 Z/28's Avatar
"The Drag Racing Director"
Ditto!
Coach
Old Nov 12, 2008 | 03:33 PM
James Montigny's Avatar
Very important distinction to make when asking "which is 'best'"
Old Nov 12, 2008 | 03:54 PM
OutlawZ's Avatar
Those aren't the only companies that make shocks for our car.....
I'm run Alston Chassisworks Varishocks double adjustables..... 16 adj for compression, 16 for rebound.... I personally feel the quality is better than AFCO and strange....
and they aren't anywhere near the cost of 2 DA rear afco's..... As soon as I put them on my car I had to figure out how NOT to go on the bumper.... A problem I would rather deal with than spinning....
Old Nov 12, 2008 | 09:04 PM
JUICED96Z's Avatar
If you are serious about having a sick car and want to go fast go AFCO, want to just have something fun, go QA1.
Old Nov 12, 2008 | 09:12 PM
tuff's Avatar
8 SEC SLOPPY SHOT!!!
Santoff i here is the best but i run strange.
