Drag Racing Tech
???delete e-brake???
Old Nov 16, 2008 | 12:35 PM
nemss1's Avatar
Question ???delete e-brake???
taking off even more weight!
i have already removed the e-brake cables
HOW DO I REMOVE THE REST OF THE E-BRAKE ASSEMBLY FROM BEHIND THE ROTORS???
IS IT ATTACHED TO THE BACKING PLATE?
DO I DELETE THE BACKING PLATE TOO?
Old Nov 16, 2008 | 12:47 PM
daniel6718's Avatar
you cant caliper bolts to it
Old Nov 16, 2008 | 12:59 PM
DanZ28's Avatar
It also holds you bearing and seal in place on the axle, got to have a backing plate. I bought the Strange drag brakes, eliminates all of it and is much lighter than the stock brake setup but obviously not free weight savings.
Old Nov 16, 2008 | 01:32 PM
nemss1's Avatar
thanx much guys. how do i go about removing the e-brake assembly from the backing plate?
Old Nov 16, 2008 | 01:40 PM
Taubr Unit's Avatar
i did it to mine when i put in my 9'' but i had the backing plates off. All you need is the plate so i just use a prybar and pulled all the **** i could off. The end result is ONLY the plate, so whatever parts you see, get um off somehow, lol. Its also a cool "pimp" factor when you put them back on, looks a lot cleaner....
Old Nov 16, 2008 | 01:57 PM
nemss1's Avatar
ya i totally agree on the cleanliness. weight reduction makes our cars look cleaner haha. thanx for the help!
Old Nov 16, 2008 | 02:04 PM
Taubr Unit's Avatar
no prob. bro.
Old Nov 16, 2008 | 05:48 PM
nemss1's Avatar
do i need to keep the round dush shield in front of the backing plate since i removed my e-brake???
the fronts dont have dust shields so i was wondering
Old Nov 16, 2008 | 07:36 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
I cut mine off of my 93. It was right around 12 lbs if I remember correctly.
https://ls1tech.com/forums/9163282-post123.html
Old Nov 16, 2008 | 07:39 PM
DanZ28's Avatar
I think if you pull the caliper and the rotor off, you can get to all the e-brake stuff and just remove it all. If you have ABS, you can remove the sensors as well. I don't remember mine having a dust shield but I see no reason you can't remove it. Did you also remove the e-brake handle assembly from inside the car?
Old Nov 16, 2008 | 08:57 PM
Fast_94_Z's Avatar
i bought aftermarket brakes lol.
Old Nov 16, 2008 | 09:07 PM
Taubr Unit's Avatar
i dont have the dust shield, threw it all away.
Old Nov 16, 2008 | 11:35 PM
nemss1's Avatar
yep, pulled the calipers and rotors off and removed the e-brake assembly. also removed the ABS sensors and pryed the reluctor rings off of the axles. ya im pulling the axles out tomorrow to remove the dust shields and reluctor rings. i didnt remove the e-brake handle (trying to keep my interior looking stock), but i removed the cable going to it, all the cables, and brackets on the axles
Old Nov 17, 2008 | 04:32 PM
DanZ28's Avatar
Good deal!
I didn't really notice my brake handle being gone much
Old Nov 17, 2008 | 05:25 PM
Fast_94_Z's Avatar
not to jack this thread but hows that cheetach shifter compared to like a percision shifter or a b&m rachet shifter or anything else on the market?
Old Nov 17, 2008 | 05:47 PM
nemss1's Avatar
Good deal!
removed axles and reluctor rings today! all went smoothly
Old Nov 18, 2008 | 01:20 PM
OWN3D BY MY PROF!
The ebrake handle is probably 6 lbs by itself if not more. You won't notice it being gone.
Taubr Unit from looking at your pictures I think I got everything off of mine, but I'm not sure. 93 with LT1 rear brakes:
Old Nov 18, 2008 | 04:08 PM
Taubr Unit's Avatar
well i have ls1 brakes so there a little different then ures so i couldnt tell ya exactely
Old Nov 18, 2008 | 09:49 PM
Taubr Unit's Avatar
even though your done, heres a pic incase or for future refrence for other people......
Old Nov 18, 2008 | 10:44 PM
nemss1's Avatar
yup! mine looks like that!
