Drag Racing Tech
how to install a push button ignition
Old Nov 20, 2008 | 07:10 PM
elitopus2002Z's Avatar
Default how to install a push button ignition
After i disable vats how would i go about installing a push button ignition? Car is an 02 z
Old Nov 20, 2008 | 08:54 PM
Josh@KY-Turbo's Avatar
Basic run down of how I did mine.
Key in the ON posistion.
Toggle switch (single psostion type. Spring returned to center). Wired to a 12v source and to the starter solenoid.
Pretty much get in the car. Key the ignition to the on posistion. Bump the starter switch and you running.
