Drag Racing Tech
Lugnuts for Centerline Convo Pro wheels ???
Old Sep 25, 2003 | 10:43 AM
ta25th's Avatar
Default Lugnuts for Centerline Convo Pro wheels ???
Is everyone using the 12x1.5 with .500 inch shank lug nuts and washers to mount their Centerline Convo Pros? The reason I ask is because the shank extends past the back of the wheel and it looks like it would prevent the lug nut from tightening the wheel on to the hub. ie. the lug nut looks like it would bottom out before it tightened up the wheel.
Thanks,
Shawn
Old Sep 25, 2003 | 10:50 AM
JTM's Avatar
JTM
Default Re: Lugnuts for Centerline Convo Pro wheels ???
Yeah you need to use those lugnuts, they fit fine.
Old Sep 25, 2003 | 10:51 AM
ta25th's Avatar
Thanks...the guy at the tuner shop said the lugnuts were too long because they protruded past the wheel in the back.
Old Sep 25, 2003 | 04:47 PM
theblur98ss's Avatar
I just got lugs from summit. Do I need some type of washers too?
Old Sep 26, 2003 | 04:10 PM
z-ya's Avatar
The specs for the washers are in the instructions for the wheels I sent you Brad.
Old Sep 26, 2003 | 09:27 PM
CamaroCain's Avatar
the should come together. i just ordered a fresh set a week ago and the lug nuts and washers come together, part #L-5115.
Old Sep 27, 2003 | 12:33 AM
taqwache's Avatar
if you dont have the washers on them, then that is the problem. with out them your lug nuts will bottom out before the rim is tight. then you will have serious problems. the washers take up the extra clearence. these rims need to washers no matter what!!!
Old Sep 27, 2003 | 09:29 AM
Ok now I'm lost. Jeg's says to use acorn style lugnuts so that's what I got. They have a taper on the wheel side. I checked the instructions that came with the wheels and it says no washers needed with the acorns but to use washers with the mags. It also says it depends if the wheel has a chamfer on it. I just checked all 4 of mine and they are flat with no chamfer. So do I need differant lugs now???
Old Sep 27, 2003 | 09:53 AM
DMcRacer's Avatar
I went to Auto Zone and picked up lug nuts and washers. My lugs are shanked, not acorn.
Old Sep 29, 2003 | 03:42 AM
ta25th's Avatar
...I just checked all 4 of mine and they are flat with no chamfer. So do I need differant lugs now???
Yes.
Old Jun 19, 2004 | 02:03 PM
Humanoid's Avatar
I just ordered the L-5115's for my Warriors. Thanks for the data.
Old Jun 20, 2004 | 08:47 AM
CHRISPY's Avatar
You do NOT want to use a tapered/Acorn lug. You want flat.
The part list above is correct
CLL-L5115 12mm x 1.5 mectric, right-hand-thread, .500 in. shank, open-end, lug nut
