Poor Trap Speed
I need some help from those with more experience than me in Drag Racing. I feel like my vette is running much slower trap #s than the sum of my parts would suggest it should run. The car is an 97 coupe M6 w/ 4.10 gears and a 402. On the strip scales the car weighed in at 3300 pounds. The car dynoed at 530 rwhp/490tq. My only trip to the drag strip in the car netted me a 12.2 @ 118 with a 2.0 60ft. I understand the slow ET as I am not launching the car very hard(Blows the street tires off with anything more than ~2k rpm). Does that trap number sound right? The car runs like a raped ape on the street.
TIA
Something is up with yours..that is a low 11's trap speed with a good hook.
I don't know what RWHP mine has, haven't had the chance to Dyno it.
1. shift just before the traps
2. letting the car nose over before the next shift.
3. track conditions aren't great
4. it could be the clutch?
These are just some of the questions I have for ya.
my guess would be the driver, but I cant imagine you being so terrible that you would kill off 10+ mph. your gearing is correct, though 3.90's would suit your power level better with a 26" tires IF you were trapping what you should. I have seen bad shifting kill 4, maybe 5 mph, but not 10, so I don't think its completly you.
I would have to say that you may be getting severe false knock. When your car is stationary on the dyno it may not show up, but going down the track, shifting, spinning, maybe something is setting of the knock sensors?
Also, depending on the tune your car may be great on the dyno, and crap at the track. I have seen that as well. Don't forget that on the dyno you are only under load in 1 gear and for a short period of time, at the track you are in 4 gears, and for a longer period of time. A tune for a great dyno number, will not do well at the track. But that is a long shot, most of today's tuners know that.
1) I wasnt shifting like I hated my car, just like I disliked it.
2) Clutch doesnt appear to be slipping. It's an OZ700. Grabs plenty hard.
3) I'm running a 27" tall tire on the street, but that day at the track I had a 25.35" tall tire on the car. I was shifting into 5th as I ran through the traps.
4)I was logging the runs in HP Tuners and I didnt see any knock. The car was tuned on the street by me. I'm running stock timing. The dyno numbers I spoke of before are based on this tune.
I'm clueless at this point. I guess I will just have to take it back to the track and compare again. It's only been once with the current motor.
I'm sure there might be some other things going on but I'd start with that. Shifting always kills time and MPH, unless you can shift without a clutch (not recommended).
Keep us informed on your progress.
