09 ET rule...
from Rule Book
ROLL CAGE
Roll cage mandatory in cars running 10.99 (*6.99) or quicker or any car exceding 135 mph. In full-bodied cars, with unaltered firewall, floor, and body (from firewall rearward, wheeltubs permitted), runing between 10.00 (*6.40) and 10.99 (*6.99), roll bar permitted in place of roll cage. In convertinles running 10.99 (*6.99) or quicker or exceding 135 mph, roll cage mandatory
Hmm?
That basically says...
-Roll bar for 10.00 (6.40) or slower with factory Fire wall or Floorboards
-Cage for 10.99 (6.99) or 135 with altered Fire wall or Floorboards
-Cage for 10.99 (6.99) or 135 with any convertible whether stock Firewall and Floorboards or not
Explain to me how this is different???
The 11.49 rule is for ROLL BAR's not ROLL CAGES's. Big difference...
Roll bar mandatory in all cars running 11.00-11.49 seconds.
Roll cage mandatory in all vehicles running 10.99 and quicker or any car exceeding 135 mph
This is a link to NHRA's website with thw 2009 revisions to the 2008 rulebook. It says nothing about changing the requirements of when to install a cafe or roll bar. As I said, you misread this because it read the same as last year.
http://www.nhra.com/content/general.asp?articleid=17519
A 5-point minimum roll bar on a fixed roof car (t-tops okay as well if in place while racing) from 11.49 to 11.00 (7.00 1/8-mile). If the hardtop / t-top car has un-altered floors, firewall and frame rails (wheel tubs are okay), then the 5-point roll bar is good til 10.00 1/4 mile (6.40 1/8-mile). Convertibles require the 5-point bar from 13.49 (8.25 1/8-mile to 11.00 (7.00 1/8-mile). The roll bar can be bolted or welded to the floor, see diagram in the "What do I need" sticky for specs. Roll bar must be padded anywhere the driver's helmet may contact it while in the driving position. If the floor and/or firewall has been modified, then a full roll cage is required beginning at a 10.99 e.t. or any vehicle running 135 mph or faster (regardless of e.t.). A roll cage is also required on any vehicle running faster than 10.00. The roll cage can be bolted or welded to the floor, see diagram in the "What do I need" sticky for specs. Roll cage must be padded anywhere the driver's helmet may contact it while in the driving position.
Derek
