Drag Racing Tech
Line Lock not working!!!!
Old Oct 2, 2003 | 11:28 PM
DEEZ98Z's Avatar
Default Line Lock not working!!!!
OK I need help... I dont under stand what could be wrong. I ordered Summit's line lock, THAT CAME WITH NO INSTRUCTIONS So I called the tech help and followed what they told me... the only question that I had asked them was "which was the in and which was the out". I have power and I hear the silnoid click on and off but it is not locking the tires!!!! I thought this was going to be a simple install... but NOOOOOO, shyt has to be dificult. Any Ideas on what could be wrong?
Old Oct 3, 2003 | 12:44 AM
Mid-Life Speed's Avatar
Default Re: Line Lock not working!!!!
The selenoid doesnt care which port is the in/out. Be sure to bleed the selenoid before hooking up to the ABS unit.
Did you get the right input on the ABS unit ?
How are you attempting to activate the locks ?
Old Oct 3, 2003 | 01:48 AM
jmX's Avatar
jmX
You have to mash the brake pedal, THEN press and hold the button. Just pressing it while the car is sitting won't do anything unless the brake pedal is held down.
Old Oct 3, 2003 | 02:57 AM
383LQ4SS's Avatar
The summit line lock? The one that looks just like the Hurst line lock? If so...there is an in and an out. I just did one...and same thing. Swapped the lines fot the in/out and now it locks like a ****.
Either that or your now on the right line.
Old Oct 3, 2003 | 03:39 AM
Smoke_Ford's Avatar
Yes, jmX is right, you need to pump the brake up first...
Old Oct 5, 2003 | 02:30 PM
DEEZ98Z's Avatar
I fixed it .... it was the one that looks like the Hurst roll control. The in/out lines need to be on different levels. Thanks for the replies though.
